I picked up a 16' Starcraft, closed bow hull, today. A local scrap guy was making his rounds and had asked how he could go about picking up a boat that was on the ground, or if he could borrow a trailer. I loaned the guy a trailer provided he brought the boat to me not the scrap yard first.
Its 16' and a few inches long, and about 5 1/2' wide. The transom and deck pretty much look like coffee grounds but there's a deep gouge along one side just below the water line, as if it got dragged across a sharp nail. The gouge is about 2" long, and the last 4" or so are through leaving just enough of a gap to see daylight through. The gouge ends at a rib, right on a decapitated rivet. There's silicone residue all over the area, and some very messy aluminum welds, so someone knew it was there and made some attempt at a poor repair. My guess is that the last owner didn't deem it worth fixing.
At this point I have only a few bags of empty beer cans in trade for it invested, and best of all its even got a title.
I was thinking of just cleaning and welding the area but my concern is that when it cools its most likely going to crack.
Am I right in thinking that the correct repair may be to use epoxy?
The area is just below the port side spray rail where the bottom of the boat just begins to curve under. Its more on the side than on the bottom, but either way its below the water line.
I'm thinking that maybe just tapping the dent or tear closed and filling it over with JB weld or similar may be the best repair, plus replacing the one bad rivet. Most of the open tear is under a rib from the inside, so access inside is limited, unless I remove a rib, but that to me would be just making the whole problem worse.
There area also about 30 or so abandoned holes in the lower transom that are filled with various sealers and screws that will also need to be fixed. I thought about using Alumaweld sticks but both locations are just too close to either the side seam or the transom seam rivets, which appear to have some sort of sealer in between.
Any suggestions? (Sorry no pics yet, I tried to get a few but its sitting on the trailer and the bunk covers the gouge on the side nearly perfectly. I'll get a few pics but that will have to wait till the weekend until I can lift the boat off the trailer enough to see the whole area better in daylight).
