I bought a clean looking Starcraft aluminum boat a few months ago with a four stroke Mercury motor on the back, after a few times out I noticed water leaking in from behind the transom panel when I slowed the boat.
Further investigation after removing the motor, corner caps, inner aluminum and wood shows the inside of the transom is severely corroded, only where the wood touched the aluminum.
The wood is like new, no rot, no damage at all. I can put my finger through the aluminum all along the bottom edge where the wood sat. Right now, after pulling the wood away, I've got holes that are 6 inches long and an inch high, and I suppose I could poke my finger through all the way across that line side to side. The rest of the hull is shiny, clean and like new. Its never seen salt as far as I know, its powered by a manual start motor with no charging system so I don't think its an electrolosys issue, and the wood doesn't appear to be pressure treated.
I talked to a local welder and they won't touch it, he said none of the transom is solid enough to weld on.
I'm thinking of taking a sheet of .040 aluminum about 4" larger than the wood panel, and riveting it all the way around with some metal adhesive in between.
The top rail of the transom is fine, as is the top 3" or so of the metal, the main damage is along the bottom edge of the wood, roughly the lower 2" of where the wood sat against the outer panel. The inner panel is rotted too but that's easy to just replace. A buddy said I should just grind and sand the holes and epoxy some back plates in place and then use marine filler to fill the exterior damage for appearance.
I'm leaning towards all new metal but I can't weld aluminum, or at least I'm not that good at the tig welder to do something that counts like the back of my boat.
I can bang rivets though.
I need to figure out how to fix this and then how to prevent it in the future.
Since the wood is fine, I'd be putting it back in, but I'd lean toward sealing it or putting some sort of plastic barrier between it and the aluminum.
