brandonkbrock
- Sep 3, 2011
- 11
I just recently bought a 1981 Ebbtide Dyna Trak with a Evinrude Starflite 135 HP engine that's not running very well. Here's what I've done so far and what has happened.
1. It took a while to crank and then would shut off when throttled up in a barrel of water (this was at the guy's house I bought it from... he lived an hour from the nearest water, so unfortunately I couldn't take it out to test in water. It was a good deal, so I bought it anyway).
2. I put fresh gas and oil mix in the tank
3. I took it to the lake and it would not start at all. It would turn over, fire for a second, and then peter out.
4. I made sure it was getting fuel through the line
5. I put a new battery on it because the old one wouldn't hold a charge
6. I put 4 new spark plugs on it (the motor recommends Champion UL77V but the auto stores in my area were out so I used NGK comps).
7. Took carb off and cleaned it
8. It fired up pretty easily w/ water hose and muffs when I put the carb back on, ran for a while, and then shut off. There's a little smoke coming out of the two holes on back of motor (where normally water would spit out). The water that is coming out of the slots in the foot is hot.
Any ideas? The guy I bought it from said he had changed the water pump a few months ago, but I don't trust him. Could it be overheating? Any other suggestions? Do these engines have fuel pumps?
Thanks!
Thanks!
