staring problems
I HVE 1973,JONSOM 115 V4,STARTS,UP GOOD COLD<br />HAVE REBUILT CARB,NEW POWER PACK,AND RECTIFIER,<br />REUN GOOD NO MIS FIRE,NE HESITATION,NOBACK FIRING<br />AFTER I GET IT STARTED,GO TOO MY FISHING SPOT FISH<br />FOR.20-30 MINUTES IT IS HARD TOO START UP AGAIN<br />HAVE TOO CHOKE ENGINE,AND CRANKING OVER UNTILL BATTERY IS ALMOST RUN DOWN,OUT OF THE WATER WHEN TESTING DOES NOT GIVR ME ANY PROBLEMS WIIL START UPEVERY TIME WITH NO CONTINUOS CRANKING [/LIST]
o/b tech
Re: staring problems
Is the vent open on the gas tank and after sitting for twenty minutes you will probably need to squeeze the primer bulb again to make sure the fuel system is primed.<br /><br />Did you rebuild both carbs? and are the floats set at the right height?<br /><br />It sounds like you may still have a fuel problem.
