Start motor problem?
vandy21
I have a 1988 140hp Johnson which is not starting. The motor is turning, but the small gear that is supposed to "jump" up and spin the flywheel isn't "jumping". Is the starter motor shot or is there something I can do to fix it? Thanks
petryshyn
Re: Start motor problem?
Lift the gear up by hand and lube the spline with TCW-3
Other things that will cause this:
-low battery
-reversed battery cables :(
-incorrectly rebuilt starter
JB
Or the far most common cause: Bad connections of the battery cables to the engine.
tashasdaddy
as JB said.
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
vandy21
Ok, thanks a lot guys, I'll try those ideas.
