See picture... using a remote switch to jump battery power to the ignition connection at the starter solenoid, the motor would crank over just fine. I noticed however that the starter is not coming back down like it was before... normally it would lift up to engage the fly-wheel... now it just stays up. It does not seem to be mechanically jambed.. everything rotates free... no major binding. Just to be sure I disconnected all power from the battery, and checked voltage at the ignition port of the solenoid.... no voltage.
I tried rotating the flywheel clockwise (by hand) but the starter gear does not go down, I tapped on it and a metal to metal knock is heard inside the starter as if something is holding it up. I sprayed some wd-40 around the shaft to see if that will help.. the engine is not running right now due to an ignition fault... need to get this to drop down for when the motor is ready to spark... ...... any idea how to get it to drop back down? time for a new starter.....? I didn't want to hammer on it too hard if there is something else to check... thanks for any tips.
