Starter bendix will not stay engaged
Jlockler
Motor is an 89 25 hp. Bendix only engages flywheel for about 1 second sometimes 2. I've lubed the shaft and cleaned connections. It has only recently started doing this. What is odd is I did a compression check and when the spark plugs were pulled the bendix would stay engaged as long as I had the key turned. But as soon as the plugs were replaced it was back to 1 second. Compression was good at around 90 psi on each cylinder btw.
check your starter connections, including where it bolts to the starter
F_R
Check battery and cables connections. It probably is cranking slow because of low voltage.
Jlockler
I just noticed the battery the motor is hooked up to is a deep cycle and not a cranking battery. Could this be the problem? Cold crank is 750 amps which should be more than enough for a small 2 stroke but it just doesn't seem right.
