starter clicking
bamaboater
97 Mercruiser 3.0 I/O....just replaced the starter and have checked battery for power. When i replaced the starter the clicking got louder but thats all i get when i turn the switch. Any ideas would be appreciated.
maxxman04
Re: starter clicking
starter assist (slave) solenoid, seperate from starter. cable/wire connections loose, broken, corroded. not enough amperage from battery to crank motor
P 0 P E Y E
Clicking or chatter usually denotes low voltage to the accessory in question.
A solid, abrupt C L U N K usually denotes a locked up engine or drive
Les Robb
Agree with maxxmanand popeye, get a bronze or stainless toothbrush and clean all your terminal ends to starter and the ground area if it's grounded to the motor through the mounting bolts. (Maybe painted) And it never hurts to refresh the battery connections It could be the starter, won't be the first time that's happened.
P 0 P E Y E
use a pair of jumper cables right to the starter and a good ground
Remove on cable at a time to see which one needs a fix
