starter/flywheel
clasavi
All,
I removed the starter this weekend for maintance. When i reinstall it, should i use grease on the flywheel?
Thank you
Don S
Re: starter/flywheel
No, just put it on dry. The grease would only hold grit and cause more wear than normal.
clasavi
thank you for the prompt reply. how about a nubmer three oil? i read online that some people do so... what do you think?
Ayuh,... Starters,+ ring gears run against each other Dry everyday...
But,...
If you wanta grease it or oil it,...
Go right ahead, it's Your barge... It won't hurt a thing...
Gary H NC
With the engine running it will just sling the grease inside the bell housing...
Useless really....No need for it but if it makes you feel better...oil it..:)
