Starter For Magnum 350
joey nathan
*1995 Ski-Ray Inboard* 0F616339 engine serial number: Someone please share the part number for the starter No markings/numbers whatsoever on the (smallish) starter itself. Thanks in advance...
Ayuh,..... Is this an Inboard, or an I/O,..??
Mercruiser motor right,..?? What drive,..??
Ayuh,.... Is the starter mounted down low on the motor's block, or up high on the flywheel cover,..??
joey nathan
Down low and I have it out already. Turning the key only yielded a clicking of the solenoid. Battery load-tested good at AutoZone...
Ayuh,.... Then you should be able to find yer starter, by serial number on This page,....
joey nathan
Really baffled now. Starter checked okay at AutoZone. They hooked it up and the little gear extended outward and spun just as you'd expect. Battery load test okay also. Cleaned up ring terminals on both ends of the positive and negative cables with sandpaper.
And yet all I get when attempting to start is solenoid fluttering (like a low battery?) What am I missing here? Are AutoZones testers not reliable?
JustJason
Test your battery cables for voltage drop.... You could have rotten cables.
joey nathan
Thanks Jason,
With key on, had 12.75VDC @ starer terminal with large red cable...
JustJason
You want to measure it with the key held to start, and the starter activated. On a side note, if this is a basic lead acid battery you really shouldn't get any more than 12.6 on a fully charged battery. So make sure you disconnect any battery chargers, as they can skew your readings.
achris
More fish than mountain goat
Then check the grounds... Including the 'connection' between the starter and the engine block. I'd check for a voltage drop in the negative circuit by putting the meter leads on the starter housing and the battery negative terminal. You're looking for as LITTLE voltage as possible. Any more than about 0.2v (while trying to crank) is worthy of investigation.
Chris.....
joey nathan
JLK You're the man! That solenoid is sitting right on top of this engine! Right next to that 50A breaker. I owe you a beer! Big Ups!
BTW Why on earth would we put a solenoid in series with a solenoid?
achris
...BTW Why on earth would we put a solenoid in series with a solenoid?
Because the solenoid on the starter needs more power than can be provided directly through the key switch without burning up the wiring harness. You use a small current to pull the first solenoid, which can use heavier gauge wires so the starter solenoid can be powered.
Chris.......
JLK62
Glad I could help you find that solenoid for the solenoid. LOL You owe AllDodge a beer because he's the one who helped me figure it out, but if you're ever on lake Hartwell (GA, SC) I'll be happy to raid your cooler!
Thanks for the explanation Chris. That makes sense now.
joey nathan
Well, I may finally be on to something here. Positive cable voltage drop checked okay. Measuring from the battery negative post to the ground lug on engine block and I get 7.5V drop! Connector/conductor partially exposed under the shrink wrap at battery end shows some pretty green looking copper wire. Methinks about 8 ft. of AWG2 cable and a couple of ring terminals and I'll be good-to-go again...
achris
That'll do it every time.... :thumb:
