Starter for mercruiser 5.7, left hand rotation?
Samckay
Replaced starter on 2002 mercruiser 5.7. Turns and fires but the starter continues to thrust in repeatedly. I used a rebuild from local auto store...
Apparently the mercruiser rotate opposite (left aka counterclockwise) and thus my problem.
My questions:
-does this sound like the issue? Do not want to buy another if it is not the issue.
-where to get it? As I look on the web I see most r labeled "cw" which I presume is right handed and I need Ccw. It would seem this would not be hard to find but...
Thanks
Scott
Re: Starter for mercruiser 5.7, left hand rotation?
Ayuh,... Welcome Aboard,....
That's the standard rotatin' direction of 'bout every motor comin' outa Detroit for the last 100 years....
picklenjim
All mercruiser stern drives use a left hand rotation (ccw) engine determined by looking at the flywheel from behind the boat. Same as in a car. Also you don't want to use a automotive starter in your boat for safety reasons. Reverse rotation are very rare.
Samckay
Sorry to be dull on the subjEct but still not understanding. As I look at the description on the marine parts they are nearly all listed as "cw" which would seem opposite of the left rotation.
Is the auto starter I have rotating the proper direction for my boat or do I need opposite, or is it another issue I am facing? I was told the mercruiser rotates opposite of the auto version.
Thanks
stonyloam
You determine the rotation of the engine AND THE STARTER by looking from the stern forward. Thus CCW engine, CW starter.
Lyle29464
What he said.
If you bought it as an auto part rebuild it will be the correct rotation but you need a marine starter. Hard to say why it is not working right. could be a bad key switch, solenoid or the starter. The description "standard turn" for your engine and parts will save you a lot of headache.
