So, got started workin' on the boat again. Last winter, I had an issue with my starter, the thread on the top of the starter stripped out and lost the spring & nut (above the bendex). Anyways, fixed it (rethreaded), but began having troubles with the starter starting. Took it apart and discovered the plastic piece holding the brushes was broken and one of the brushes kinda sat in the middle. I rebuilt it to the best of my ability and let the winter run its course.
When I tried to start it this yesterday, I discovered that it wouldn't start (starter). So, armed with my trusty DVM, I when from point to point (batter/ignition/solenoid/starter) to find that everything was getting voltage. Long story short, when I bridge the gap on the start solenoid, the wrench would spark, but no movement on the starter.
My guess is that the starter is bad, I just want to see if someone else can offer an opinion.
