starter motor fuse
s1jor
after pokinh round the engine bay, i found a wire with a 35amp fuse on it coming off the starter motor, it was not plugged into anything, little more poking round found the other end of the wire dissapearing into the wiring loom, i'm guessing this wire should be connected?????????? seems to have been running without it all sumer without any problems, whats the fuse and wire?????????/<br />boat is a mariah 180 (97) engine is a 4.3 volvo sx drive (4barrel, again 97)<br /><br />thanx<br /><br />simon
Don S
Re: starter motor fuse
My guess would be for some added accessory. The Fuse holder is not a Volvo item for that year.
I don't think I'd be Hooking Up Anything,<br />Till you do a little more poking round,+ Find Where the other end of that wire comes Out of the wire loom.........
s1jor
thanks will find out where the other end goes and go from there
