Starter options for 2000 5.0 GL?
Laneman25
I think starter is bad, clicks but won't crank. Battery 12.5 volts, all cables cleaned, tried new ignition switch. Can I use the insides of a Chevy automotive starter and install in my sealed marine case? Price is $400 for a marine starter.
First, troubleshoot what the issue is. most likely bad connection and or a bad slave solenoid.
most likely its just a bad connection.
NO, you cant use the insides of an automotive starter. I paid less than $200 for a polished stainless performance starter
I dont think I paid more than $60 for a standard marine starter (hint, dont buy it from volvo)
there are 4 GM marine starters. direct drive or PMGR, and straight across (for 153 tooth flywheel) vs staggered (for 168 tooth flywheel)
Laneman25
Laneman25
I opened the starter cover, it's full of rust by the brushes. Looks like it got submerged by previous owner. Guess I'll replace it.
matt167
DB electrical usually works. It’s all China stuff and it’s cheap but it does usually work fine. They have gotten very popular
If you can get the numbers off your starter, than Napa can get a rebuild for you
Lou C
Also there are 3 and 4 terminal solenoids, check yours to make sure you get the right starter….
Laneman25
Thanks to all who replied. I also have a reputable rebuild shop that quoted 80 for a marine rebuild unless major parts are needed.
Laneman25
I ordered the DB Electrical. On my boat the starter is not too hard to remove, so if it fails in a year I'll survive.
Laneman25
I finally took it apart. Looks like it was submerged at one time. Amazing that it still worked. Commutator has chunks missing.
Lou C
they are ignition protected but not water proof!
since I'm in salt water I do change them the minute they start to sound different.
I usually have a spare ARCO in the garage, I have had good luck with their starters and alternators.
Ayuh,..... You got the last lap outa that one,......
Donald0039
The starter for my 2012 V8-300-C-A would spin but not engage and start the engine. Trying it several times and it finally engaged and started the engine. But cannot count on it. #3885317.
The Arco was $253. I found one from a Volvo Penta dealer for a little over $300. And of course a bunch of cheap Chinese ones on Amazon and eBay for less than $100.
I assume it's the solenoid or Bendix drive. I will get the old one rebuilt assuming its a Volvo Penta one.
