texas_angler_2002
- Feb 15, 2002
- 115
Hi,<br /> i replace the lower part of the starter more less the base was broke so i replaced. after putting it on i tried to start it and it acts like the battery is dead which it is not. i changed batteries and it caught the negative side on fire and acid started coming out i quickly got some pliers and took off the wing nut and pulled the wire off. i need to know what might be causing the problem. the wire going from the starter to the solenid was starting to melt from the heat. only turned the key over for about 20 seconds. any help is appreciated.<br /><br />85 115 rude v4...thanx
