hondakillrsx
- Jul 8, 2009
- 70
Hey guys,
Just recently when going to start my 50 horse two stroke, the starter will engage the flywheel but does not have enough "juice" to turn the flywheel. One would think this would just be a low battery issue but after that initial try, it turns over fine for as long as you want to hold the key over. It seems like the starter is starting to wear out and it just doesn't have enough power to turn the flywheel. Has anyone else had this happen to them? The weird thing is that once I stop the second time and go to turn it over again it does it again. If this makes no sense to you what so ever, I'll draw the pattern below
will raise to flywheel but not turn
turns over fine
will raise to flywheel but ot turn
turnes over fine
will raise to flywheel but not turn........
after doing this a few times it will slowly start to wear to where it doesn't turn it at all.
Please help! thanks!
turns over fine
turnes over fine
