jerryjerry05
- May 7, 2008
- 18,110
Just bought a 125/88 for parts.Owner said it hardly turns over and won't start.
I replaced the starter with a back-up.
I noticed the flywheel had a wobble(not supposed to).I removed it and saw the keyway was sheared.
Cleaned up the keyway and used a good flywheel.The other 's magnet was destroyed.
It turned over GREAT!!
Guess what???? It actually runs!!!
Now to the starter.
It was the original.NEVER cleaned never re-built NOTHING!!!
I pulled it apart.Saw the brushes were wore down and stuck.Springs were compressed a stuck.4Springs next to the right size2 after they were overheated
There was an obvious overheat situation as everything was cooked and carboned.
The armature where the brushes hit 2 of the windings were shorted out and destroyed the armature.
There was about a teaspoon of carbon/dirt in the bottom.See the pics.
So every year or 2 take the starter apart and clean it.J
Now to the starter.
