starter/selonoid
clasavi
i have a 1998 350 mercruiser I/O. i need to replace the starter selonoid and would like know if i could pick one up at the auto store Vs at the marina. can someone give me a part number? thank you
Bt Doctur
Re: starter/selonoid
there are usually 2 solenoids in a boat. The "slave" and the "main" that is on the starter.
You are referring to??????
Most cases if the main solenoiod needs work the starter SHOULD ALSO BE CHECKED
Seon
Best to bring your starter to a rewind shop and have them repair it. The auto parts starter doesn't have the "spark" arrestor that marine has...at least that's what I was told when I had my starter re-wound.
achris
More fish than mountain goat
Just click HERE and you'll have all the answers you could ever want... or not want...
Chris..........
clasavi
the starter would click when i turned the key. after 4 to 5 tries it would crank
Fishermark
Like BT Doctur says, there is more than one solenoid. Click here for a good check list before you go replacing anything.
Quote:
Originally Posted by Bond-o
Ayuh,... How did you come to that conclusion,..??
Ayuh,... Click on Fishermark's link,...
It'll save me abuncha keystrokes to explain Why I asked that question,....
The Aduts Only section of this forum has a Gold Mine of boat fixin' readin'....
Help yourself,... Good Luck....
95Monterey
The test light link/thread was old and didn't think I would get a reply posting a question there. So, I have the volvo relay type and a meter instead of test light. I assumed you disconnect relay plug because there isn't another way to make contact and check for voltage. I tested the female end of the plug and got 27 volts on A but zero on B and nothing clicked. That combination of results was not listed of what to do next or what it meant. My problem is the strong click when turning ignition but no other results/motion.? anyone?
Ayuh,... You're doing something Very Wrong....
No Way you can get 27 Volts in a 12 volt system...
Fishermark
95Monterey you might want to start a new thread of your own.
95Monterey
If you disconnect that relay you are basically reading from the positive lead straight off the starter selonoid...why wouldn't you read 24-27volts? anyway, I will start another thread. thanks.
