Starter sins - won't engage
tutt
1994 115HP merc outboard. Starter gear spins like crazy, but will not pop up to engage flywheel. Battery is good, connections tight and corrision free, even lubed armature shaft (per a related topic). Bendix spring??
Spidybot
Re: Starter sins - won't engage
I have the same motor and have seen a similar problem.<br /><br />Principle is, that the startermotor should 'kick' in with such power that the gear on the bendix cannot follow (also due to the extra weight from the mass attached to the gear) and gets pushed up, to engage the flywheel.<br /><br />For this to work the shaft must be clean and well lubed and the battery must be not only 'good' but 'very good'.<br /><br />And, ofcourse, the full power has to reach the starter motor.<br /><br />If it still doesn't work, your starter motor doesn't make full use of the power = starter needs service.<br /><br />This can be done by a good auto electrician. Standard spares fit, just remember to tell him that it is for marine use. MUCH less expensive than a new starter :)
tutt
Thanks, measured 12.5 volts at starter while cranking. oiled shaft without luck. Since it sounds like it works on centrifical(sp?) force, shouldn't I be able to manually move the gear up to the flywheel?
Spidybot
Yes, you can turn-slide it up the shaft. The pinion is mounted on the shaft as a unit (nut on shaft end). Can be removed for cleaning or replacement by holding the shaft with a wrench and turning the nut with a second wrench. It'll come off with it's return spring. This part is not repairable, officially.<br /><br />BTW: This is just another task covered in detail in a manual (ie Seloc) - link on this site
tutt
UU, you fixed it!! I held the gear with one wrech and turned the nut ontop with another. I ten kept oiling and working the gear up and down on the worm gear. THANKS! :)
Mod2
Moving to Mercury/Mariner troubles.
The Marine Doctor
The sure fire way to fix the bendix problem...that will occur again, is to replace it...bendix problems are common on inline 4 100-125 Merc's and Mariners.<br /><br />TMD
