SS MAYFLOAT
- May 17, 2001
- 6,372
I'm helping my friend get his 89 Rienell 190 ready for the water. (has the L6 250 chevy that says OMC, but attached to a Mercruiser OD) I have everything working on it except for the starter. When I bypass the solenoid on the starter itself it cranks great.<br /><br />I followed my starter wire from the switch back to another solenoid/relay that powers the starter solenoid. So I unhooked the starter switch wire and jumped the solenoid with a wire directly to the battery. It did not energize that solenoid, but when I take the starter switch wire and jumper it directly to the starter, the solenoid does engage the starter.<br /><br />Is the first solenoid there to pevent the starter switch from burning out prematurely? I haven't encounterd a starting system that uses two solenoids for the starter. Can the first solenoid be replaced with a ford type one? Thanks
