Starter support bracket question
Bearskin9898
Picked up a new starter and just noticed it doesn't have the bolt sticking up out of the starter that the nut threads into to hold it onto the support bracket. Is this bracket needed or will it be fine without it? It's on the right side of the s terminal
https://ibb.co/cqQ66o
Alumarine
Is it a marine starter? If so it should have a bolt.
It is needed on the 3.0 and I'm guessing the 2.5 as well.
is the new starter a PMGR (half the size of the old direct-drive starter shown) if so, the bracket is not needed
if the starter is a direct drive model, the bracket is needed.
