Starter Switch On 15 HP Johnson Needs Replacing
bobgritz
My Starter Ignition Switch, that is located on the front of my 15 HP 1983 motor, has been glued together 3 times and may not take a 4th repair. Is there a readily adaptable push button switch that can be substituted since new ones are $200 and there are no used ones available? I see other marine push button switches but mine has 3 wires and others seem to have only two.
yours has 2 terminals with 3 wires. Two wires are landed at the same terminal (rectifier and main battery 12v dc) switch new is $70. If you can find a marine rated switch that has 2 terminal preferable screw type with the correct size threads and amp rating then there's no reason you can not use it.
Will Bark
On my 15 Johnson I use a push button starter switch from Auto Zone or O'Rielly's which is a 60 amp switch. Mine is wired exactly as Glenn describes. This switch costs me about $15.00 and comes with a rubber screw on cover. May work for you. Good luck
bobgritz
Thanks for suggestions ... I'll head down to Autozone in next couple of days then report back as soon as I give it a try. Thank you both for the help, dealer cost for OEM and/or repro is like $195 ... ludicrous!
