hoowahfun
- Sep 1, 2016
- 186
Hi all, been reading this site for a while and recently got a new to me boat in need of some work. Boat is a 1987 Sea Sprite 195. Engine is a 1987 3.0 Mercruiser, 130HP, S/N B515218.
When I turned the ignition switch I hear a click/clunking sound coming from the general area where the starter is located. I first checked the battery voltage and charged it up, then tested and got the same result. My next approach was to check and clean the electrical connections and of course the first one I try to remove breaks part of the back end off the starter solenoid. The threaded bolt that connected the big red cable and another one broke apart and now the inside is exposed. Obviously that will need to be replaced. Although I'm pretty good mechanically, I'm not the best at following along with electrical stuff so hope these aren't previously answered questions. I tried some searches, but didn't find anything matching my situation. My questions are as follows (will upload pics when I get to the 3 post minimum):
1) Is there a way to test the starter as it is to see if it operates correctly? On or off the boat? Trying to avoid buying the whole starter assembly if I just need the solenoid. I could buy a solenoid and check, but then if the starter is bad I would have to buy a whole unit since I can't seem to find just the starter without the solenoid.
2) Can I also test the other relay/solenoid/switch thing next to the circuit breaker without fixing anything at this point? Trying to get an idea of the scope of my starting problem.
3) What position is the 50A circuit breaker reset button supposed to be in? Not sure if it's tripped or not. Doesn't easily push in like I expected and I don't want to force it and break it if its fine. How hard are these to push in to reset?
Many thanks!
Many thanks!
