I have a 1988 3.7L 4cl Mercruiser I/o that I have rebuilt and everything was fine she fired right up but the starter will not disengage. My first thought was Neutral Safety Switch, Nope Then I thought Maybe just a bad starter Nope same problem with new starter, I tried shimming the starter but still had the same results. It almost feels like the ignition switch is not kicking back to the run position after start up could this possible be the problem? That is my educated gues but I wanted to get some more opinions on the matter prior to replacing and rewiring the ignition switch. Thanks for any and all thoughts and comments
