82montauk
- Jul 13, 2010
- 19
E90FPLEEC. The starter will not engage the flywheel. I replaced the solenoid and replaced the springs/brushes in the starter. When I tried to start after that, the starter kept spinning even after I turned the ignition back off - disconnected the battery asap, but not before some smoke/sparks were coming from the starter. Didn't do much besides wiggling the ignition wires at the controls, but when I reconnected the battery, it is back to the same state. Starter spins, but won't engage. Every thirty-or-so tries it will engage and start. Is there something I can fix on the bindex? The starter doesn't look like it is supposed to raise/engage flywheel when energized, because the starter gear installs with a free-spinning gear below the flywheel.
Thanks in advance.
Thanks in advance.
