starter
josh smith
where are the bolts to take the starter off of an early 70's mercruiser 120 h.p. inboard GM 4 cyl? And what is the easiest way to go about it?
Re: starter
Up, from the bottom......<br />2 bolts... 9/16ths" heads...<br />You'll find you need to remove the Flywheel Housing Cover, to get a socket onto the rear-most bolt.......<br />There Might be a small bracket on the front of the starter.....<br />And, Of Course, the Nuts holding the Wires to the Solenoid..........<br /><br />
Have Someone Else Do It............... :D <br /><br />Welcome to iboats.......
