Starting cold engine techniques.... whats yours?
WIrED
Just asking, because...my 90hp IN6 seems to take forever to start when cold....but im sure Im doing something wrong...because when its warm it starts in less than a full crank....even when it has been sitting for 1 hour it still starts no problem.....its the very 1st start of the day I have problems with......<br /><br />I squeeze bulb.....hit and hold choke......fast idle up about 1/2 way......turn key......any other suggestions for a further (or better) method<br /><br />-THX-
CaptainPuget
Re: Starting cold engine techniques.... whats yours?
I have a primer, not a choke (1985 115hp) but here’s what works for me for the first start of the day:<br /><br />Engine trimmed all the way down<br />In neutral, throttle up all the way<br />Pump the bulb until firm <br />Prime it about 3 times<br />Push the key in and crank<br />After it starts I usually have to hit the primer a couple more times before it gets going<br />Of course you have to back off the throttle as the RPMs go up.<br /><br />After that it starts right up for the rest of the day – maybe with a little throttle.
emckelvy
Check the choke shutters and make sure they're coming up tight against the carbs, as this will make a difference. Maybe you need to give it more throttle when starting. Another thing is too pump the bulb 'til REAL hard as this, on some models, will force fuel past the float needles and in effect prime the motor. This was virtually a mandatory starting drill for all the old inline Mercs. My 1964 1000 wouldn't start well unless it had fuel dribbling out the carbs!<br /><br />Another good trick I've heard of is to remove the choke shutters and retrofit the primer valve to older motors. Tie the discharge of the primer valve into the bleed hose assy at the side of the intake manifold. This puts fuel right into the motor and will fire it off instantly. You connect the wire which formerly hooked to the choke solenoid, to the primer valve solenoid.<br /><br />A friend of mine is having problems with his motor after rebuild (runs great but that pesky cold start!), and he's thinking about doing the primer thing. <br /><br />I imagine you could pull a primer valve off of any modern motor which used one. Of course one off an I-6 would fit perfectly!
Elmer Fudge
1. trim motor down<br /> 2. pump the bulb until it's firm<br /> 3. give it approx 1/4 throttle<br /> 4. choke and start<br /> if it dies after a few seconds,i usually take the throttle off, choke and start and that does it for me everytime.
