I have wiring diagrams ,from the mercruiser shop book. Tough following, reaching out too fellow boaters, that possibly had simuliar issues or a boater with knowledge in this area
I have a 1984 mercruiser 488 engine. ( ford engine )
4 cylinder
Living with an electrical starting issue for quite some time.
WHen boat was in for engine work shop saw what I was talking about. They think electrical harness has too be changed. But once they seperated the prongs in harness it worked fine.
Then it acted up again months later.
I did the same , connections are clean, no visual breaks, good firm connection.
Got it going. Woking fine, then a Month later won't start
Time as come too correct this issue.
A wire must be shorting out, some were in coil area or electrical harness
Most times difficult starting. Eventually I get it started and once started it starts first turn of key
Once cold, wont start
Seperate electrical harness from male and female ends, some times this gets it going, othertimes no.
Other day would not start at all.
Neighbor was helping he has more knowldege
He ran a hot wire from starter postive too positive on coil. Started right up. and started without jumper many times
Later that day I tried starting and no luck, had too run jumper was tough starting but eventually started. Once it started and ran a few minutes was able too shut off and restart with out jumper wire many times
There are two positive wires going too coil , I beleive one is the purple/ yellow other is purplish in color
I beleive purple/yellow goes from one of the two legs from starter senolid. Other wire not sure, ( does it go from coil too key?) The other yellow/ red off prong of starter senolid goes too safety switch off of throttle. WOrks as it should
Negative has a gray coming in from harness ( not sure from were ) but goes from harness too neg of coil pig tales with a black wire which goes under dist.cap.
If one of the two wires had a split some were it would not start after jumper wire was removed, but it starts first turn of key once its started from cold start.
During past few months, purchased, new key switch, coil, starter senolid, new points, new plugs,
SO put your thinking hats on
What wiring should I be searching for ?????
Going from harness too coil mercruiser book says its a resister wiring, not easily replaced.
If I run my own wiring what should I do ?
SIDE NOTE
Replaced unreliable stator regulator charging with a one wire marine alternator.
All old stator and regulator wiring was cut, some were removed others caped.
SIDE NOTE
4 barrel carb , ( not sure what part is called ) there are two wires one connection, used for cold starting.
Most of this wiring is under tape, not sure were they come from ,do they pig tale off positive of coil wiring?
When I was feeling around back of carb, I took wiring off, felt a little warm and once I removed battery needle on dash jumped to around 14 volts, when I re- attached , went down a lot, like there is a drain ???
Could be un related or the cause of my problems , All in same general area
thanks
al
4 cylinder
SIDE NOTE
SIDE NOTE
thanks
al
