Hi
Got a new reman 4.3 block with various new parts,merc alpha one gen one.The engine is in the boat,but the drive is off.I just want to start it and idle it,so that I can adjust the timing,idle and check for leaks.
Can i start the engine with a water hose directly connected to the transom shield?The drive is off so there is no external pump to help flow.I measured the flow of the hose to 2 gallons a minute with quite good pressure.I think I can improve flow by shortening the hose if needed.
I made a hose connection to a soda jug to serve as a temporary fuel source.Will the fuel flow(pressure) be sufficient with the jug lifted higher than the carb?The carb is a edelbrock 1409 4bbl marine carb.
Also was thinking about removing the plugs and cranking the engine by hand to get engine lubricated prior to its first start.
Check last post!
Check last post!
