Starting from scratch Mercruiser 165
79Glastron
So I bought a new boat and it didn't come with a prop (stolen) and I'm in need of some sound advice on which one I should get. Boat: 1976 Aerocraft Browning Monte Carlo 19' closed bow, maybe around 2000 lbs? Not sure
Drive:
MC-1 Mercruiser 165 inline 6.
Are one drive props the same as alpha props? I'm thinking not if I remember correctly. Let me know what you guys think I should try first!
Thanks
Re: Starting from scratch Mercruiser 165
Drive:
Thanks
Ayuh,.... The props interchange with ALL the Merc. 4, 3/4" Large gear case drives, the Big outboards included,...
I'd try a 19",...
it's 'bout middle of the range available, 'n even if not Right, it'll probably make a good back up prop...
