raven1978
- May 19, 2009
- 99
hi all....i have a problem that i think i know what the problem is but need help/insight....i have a 1988 evinrude 50hp model e50tlccs w/omc controls. I went to start the boat at the launch this morning, and the engine was turning over slow...really slow. Eventually it did start but not being happy about it i loaded back up and drove home. Testing in the driveway i have 12.6 v on the battery, & no voltage drop on the starter. I tried to start it again and it did the same thing slow to turn over, but this time i saw smoke coming from the wiring from the battery to the ignition switch/key. I checked the battery terminals and the negative side was very warm and positive was cool to the touch. I placed my hand on the shell of the starter and it too was really warm. I opened the starter and it's full of black crud from what im guessing is the brushes in it. My question is, would a bad starter behave like this (slow turning over), and cause too much current being applied and cause the wiring to melt? Everything else checks out ok for wiring and fuses. Oh and btw to eliminate the battery as the root cause i swapped it out with another one that i have and it did the same thing. I believe the starter is the issue, but i would like some other people to chime in as i am not very mechanically inclined.
Please help i wanna go fishing
if this is not in the right area i do apologize.
thanx
rAven
thanx
rAven
