FreeBeeTony
- May 15, 2002
- 3,995
I am looking at a boat (24' Grady Offshore) with a Merc 260 (5.7L) I/O. It's FWC'd and the raw water inlet is through the hull with the engine mounted raw water pump. How can this be easily rigged so I can start it out of the water with or without the drive connected. Is there a fixture of somekind to connect a hose to the thru hull fitting like the muffs on a O/D?<br /><br />Also.........when the pump is not used in the O/D, is it still used to cool the O/D? Or is it eliminated altogether?
