Starting Method
Captn Dave
Where does everyone place their throttle when starting?<br />I'm talking about carb engines with remote controls.<br />I've always kept the throttle at Idle. I know some people and have read where others advance the throttle some. <br /><br />What do you guys do?<br />What do the pros say?
timmathis
Re: Starting Method
It all depends on the motor. Most have a warm up lever and choke. Usually pump bulb, choke and keep at idle to start. With old mercury inlines pump bulb untill firm and then 2 extra pumps,choke at idle then warm up with warm up lever. Some others you have to be careful and don't flood them. Like I said it all depends on the year, make and model. Tim
WillyBWright
Re: Starting Method
There are carbureted motors that need the idle lever left at idle. Those include anything with an automatic choke (usually 4-strokes but not always), and a lot of Merc inline 3- and 4-cylinder 2-strokes with daisy reeds. We could be a lot more specific if we knew what you have.
Captn Dave
Re: Starting Method
I have a 1989 Johnson 225 and also a 1990 140. <br />Both of these engines have primer solenoids.
Solittle
Re: Starting Method
All of the engines I have had had a unique "personality" for best starting. On my 1987 V4s I crack the throttle in neutral and use the primer. They like that.
