I feel like the village idiot here. My boat was put in storage for about 18 months. When I went to get it out, I lifted the cover off and there was my brand new bottle of Sta-ble sitting unopened on the deck. I apparently forgot to put it in & run the motor before I left. Now, when I try to start the motor it Cranks OK, and I checked to make sure I have good spark, but it won't start. The bulb will fill the the fuel filter (see-thru plastic housing), so I know there's no blockage from the tank to the motor. The oiling system seems to be working OK also because the plugs are getting oil soaked when I crank it. I'm a bit hesitant to take anything else apart to see if it's gummed up. Any advice??
Engine: 2000 Yamaha SX 150 salt water series
Fuel and oil injection
Direct ignition
Jeff B
Lawrenceville GA
Direct ignition
Jeff B
Lawrenceville GA
