stefangunter
- Nov 18, 2004
- 2
I have a 96 Mercruiser Sport Jet 120xr, with just 103 hours, which all of a sudden is having problems starting and remain running. It ran perfect last week but the last time I took it out it had trouble starting. Once it did start it would stall when any throttle was given to it. After a couple of tries with slowly apppling the trrottle it would work fine and accerate with ease. Then when the motor is turned off it does the same thing again. After about the fifth time of this it would refuse to start for about 20 minutes. So I sprayed a little starting fluid in the intake (I know this is a no, no but just wanted to see if it would fire) and it ran great until the fluid was burned out. I figure this would be the fuel pump but would appreciate a second oppinion before I start taking it apart. Also it has had a problem with the starter over-heating when the boat ignition is left in the on position for extended time and the boat is not running. Not sure if the two can be related or not but the starter turns fine as long as I don't leave the ignition on. I really would appreciate your knowledgable advice.
