85volvosunbirdman
- Jul 15, 2009
- 39
I took my boat out yesterday and it ran fine and started and shut off a couple of times with no problem. Untill the last time It would turn over buy would not start. Luckilly after a good five minutes of on and off trying and a can of starting fluid out of my emergency box it started sputtering and finally started. I did an oil change before my last trip out and put too much oil in and when I was running at 4000rpm the engine was bogging out and spirting oil everywhere so I took it home and sucked oil out and cleaned the boat. Did I break anything with too much oil? Also I am planning on a tune up including replacing points with electronic. Would this help?
This is an 85 Sunbird with a aq 125a 270 outdrive.
