Hi all, I'm looking for some guidance with my '89 Force 85 hp.
First, had some quirky starting issues... wouldn't turn over every time I turned the key. Then it did after shifting into forward, then back to neutral.
Boat started and ran fine a couple of times for 2-3 hours. Then, stalled and could not be restarted. First time, one of the plug wires had come off. Last time, not sure, but haven't been able to restart. The top plug connector wire also now seems to be cracked, which I taped up with electrical tape.
Battery is new and recharged to full, but motor doesn't seem to crank fast enough to get it started. A couple of times previously, I had to push in the choke manually to get it started initially, since choking by pushing key in doesn't seem to move the choke gizmo very far.
Any suggestions for troubleshooting starting and stall/won't restart issues?
Thanks so much.
Thanks so much.
