I,m having problems starting the motor,it turns real slow, not fast enough to start, I,ve bench checked the starter and it,s working fine, the battery is charged all the way, and I checked the wiring that I could
Remove the plugs and do a compression test.
Clean the starter.Easy to take apart.
I made a brush jig from an old liscense plate.
The if that's ok check the oil in the lower.Water?
Pull the lower,sometimes a bearing rusts and starts to sieze?
Grounds all tight?
