Re: Starting Problems
I like to say thanks to you for sharing the technique for starting my merc 1150. I decided to get a new cranking battery, charge the battery all the way and filled my test plastic barrel about half full of water. I pumped the primer bulb good and hard, then one addition pump. I opened the warm up lever all the way, pushed the choke button in and crank it over for about thirty seconds, stopped and did it again for about thirty seconds, on the next time I crank it over that 1150 fired up. It cranked off in about two minutes and this engine has never done that on a cold start. I will try it again tomorrow to back up that two minute cranking time. Thanks a lot to all of you for your help. This technique really worked and I will continue to use it. Now, at the boat ramp I will not hesitate, I will get in the line and have my merc 1150 ready to go.
Once again thanks to all of you.
