Starting trouble 69 Sportwin
nojretlas
New to 2 strokes so I need some time to catch up.......after I run the motor for a while it is giving me hell to start up again. It starts up on the first pull when I first get in the water. I am not sure if I use the choke when the motor is warm or not? Any help would be appreciated.
Thanks
Xcusme
Re: Starting trouble 69 Sportwin
As a general rule, you shouldn't have to choke a warm motor, just advance the throttle to Start and pull the rope or bump the key. But you circumstances may vary depending on the motor.
