NewerBoater
- Oct 28, 2015
- 23
Hi, thanks in advance for any help with locating my engine model number and what to do next with my starting issue...as i'm getting frustrated with my '97 Four Winns 190 Horizon RX, Volvo Penta 4.3 GL...
Issue 1- I CANNOT find the model number after hunting several times, the decals are no longer there, (I've seen the volvo FAQ and the thread on here showing the tag location but no luck finding it) does anyone have a picture of their tag that is visible without removing the lower unit?
I took it in to a mechanic recently because it died after running all day. $1600 later - after pulling the motor to fix the stripped starter bolts, replace gimbal/u-joint/bellows, clear water from cylinders, and impeller - boat was up and running again...I am now having issue 2 of getting the engine started... it cranks and cranks, just will not kick over... I took it back to the mechanic and he got it started telling me he never touched anything with the ignition, saying I must have flooded it or I don't know how to start a carbureted engine and I watched him start it with ease. Of course the problem is back after the boat sat for a month or so...
So after researching forums, I decided to replace the spark plugs and dist cap/rotor. Felt accomplished, but still have the same issue cranking and not starting. (I've replaced the ignition switch earlier this year as well). Was thinking of going back to a new mechanic, but decided to ask for help before I put more $ into this older boat. I'm suspicious of the fuel pump from what i've read, but once the boat is warm, i've never had any issues while cruising or restarting. Is there any easy/amateur way to confirm the fuel pump is functioning properly? Any suggestions to try for starting it? (checked the safety lanyard, worked the throttle - full, toggled, every location, tried manually choking, tried manually throttling)
