1994 5.8L Fi PMDA.
Had intermittent starting issues for a while where I'd turn the key and get nothing. Decided to tap on the typical Ford 4 terminal solenoid and voila...it started. Continued to test it each time I got nothing after turning the key and everytime I tapped the solenoid it started. My theory was I needed a new solenoid so I bought one and installed it. Turned the key and I got nothing. Switched from battery 1 to battery 2 and then I got chattering from the starter like you get when your battery is weak and can't fully turn the starter. Load tested battery 1. Didn't really pass but didn't have any issues previous. Load tested battery 2. Held but was weak. Put it on the charger. Went out and bought a new battery 1. Hooked it up and same thing....chattering of the starter. Pulled the starter and got it tested. Passed. Now, I have no I idea or what to do next except install the old solenoid and see what happens. Please help! Thanks!
