WinnerCougar74
- May 12, 2020
- 252
I thought this might be an interesting and informative post. What do you do when starting your Chrysler outboard?
Here is what I do with my 1974 135hp.
1. Lower motor into the water.
2. Pump gas bulb until firm (if it's not to noisy you can hear that the gas stops filling the float bowl)
3. Pull button out of throttle/shift control
4. Move throttle forward about halfway.
5. Push and hold key in to activate choke (always nice when you hear the choke click)
6. Turn to start and hold there until motor starts (not more than 10 seconds so I don't overheat the starter)
The length of time that I have to hold in the start position is based on hold cold it is outside. After the motor warms up I usually just start it right up, no choking or increased throttle.
