MODELS 30 JET 40 (4 CYL) With Serial Numbers<br />United States 0C159200 and Above . . . . . . .<br />Belgium 9570305 and Above . . . . . . . . . . .<br />Canada 0A748269 and Above . . . . . . . . . . . .<br /><br />I have the Belgium one with the model #09682784.I can see it has a black stator on it by looking under the flywheel.How can you tell if it's a 9 amp. or 16 amp. stator without removing the flywheel? I'm wanting to perform this test on it but don't know wich one it is.Stator Test (Black Stator)<br />1. Disconnect all stator leads.<br />2. Use a VOA meter and perform the following<br />checks.<br />9 AMP Stator<br />Test Leads To Ohm<br />Scale<br />Ohm<br />Reading<br />Blue and Blue/White R x 1000 5.7-8.0<br />Red and Red/White R x 1 56-76<br />Blue and Engine Ground R X 1000 No Reading<br />Red and Engine Ground R X 1000 No Reading<br />YEL and YEL R x 1 .5-1.0<br />16 AMP Stator (398-9710A33 & 398-9710A42)<br />Test Leads To Ohm<br />Scale<br />Ohm<br />Reading<br />Blue and Blue/White R x 1000 1000-1400<br />Red and Red/White R x 1 15-30<br />Blue and Engine Ground R X 1000 No Reading<br />Red and Engine Ground R X 1000 No Reading<br />YEL and YEL R x 1 .10-.50<br />NOTE: Above resistance readings are for a cold engine<br />(room temperature). Resistance will increase if<br />engine is warm.<br />If meter readings are other than specified, replace<br />stator./ma<br /> Any help would be nice and thanks in advance.
