stator johnson 85ESL73M
Dali30
Last fall i found the problem,stator was leaking and caused misfire,and not fire at all. Now its spring and i need a stator. talked to a local outboard-dude,who wondered if the ignition system could be switched with another ignition system that he had laying around,with sparkplug wires attached under the flywheel or something like that,but it depended on the diameter on crank where its is bolted on. Is this guy onto something here?
I have trouble finding stator here in norway,and ebayers wont ship the used ones..would be easyer to rebuildt it with this dudes parts that he has laying around.
Doubt that the ignition under the flywheel can be made to work on your motor.-------Lots of those stators available in my area.
Dali30
Hi recerone,any chance for helping me out with a stator? tryed to pm you but that was not possible.
Maybe we can work something out.--Busy this afternoon .--Will send a private message tommorow.
Dali30
got your message racerone. its not possible to answer it. can we talk on another platform racer? maybe you can pm me your email?
