I have a 1989 Mercury Classic 50 (Serial - ob394639, Model - 1045312GD, 4 cylinder 2 stroke 45HP) that would not restart if I ran at WOT and then turned it off. It almost behaved as if flooded. That happened a couple times and now it won't start. Problem is that there was no spark at the plugs. So I pulled out the multimeter and started testing and it turns out it was a bad stator.
So I purchased a new stator to replace my 3985454a25, which looks like they didn't make anymore so I got the CDI 174-5454K1 to replace it. I installed and still had no spark in any cylinder. Checked the stator and got a resistance reading of 2.14 Kohms on Blue to Blue/White and 47.8 ohms on Red to Red/white. I then bought another stator and did nothing but check the resistance, which it matched - 2.13 and 47, and returned it.
My Seloc manual says that the resistance range across Blue & Blue/White should be 5.7 - 8.0 Kohms and Red & Red/White should be 56-76.
I have no idea what to do next? Could the stator being out of spec be the issue and if so, I have no idea how to find one that is within spec according to the Seloc manual. Or is that close enough to spec and it's something else in the electrical system (it's not kill switch wire, or the switch box - it tests barely under spec but is really close)
Any help would be super appreciated.
