stator, voltage regulator and flywheel
rzkas
Hi? please me verify this item. i bought these items for my 1995 120 force . these parts are made by CDI. the stator part number i got is 174-9710 and the voltage regulator part number is 194-5279.
Please i need to know the thread diameter or thread pattern for the flywheel puller holes. i want to go to the store and buy grade 8 bolts that i will use to remove my flywheel but they are asking for the thread pattern or diameter. pls someone tell me the bolt size and length and thread pattern. the bolts that screws to the three holes on top the flywheel.
thanks for all great ideas.
stay bless.
jason32038
Re: stator, voltage regulator and flywheel
The bolts are 1/4x20...you'll usually need either 3 or 4 inch bolts if you're using a dampner puller. For future reference 1/4" is the width of the bolt. 20 is the number of threads per inch. You'll need 1/4x20x3" or 1/4x20x4".
EDIT...Just realized you mentioned it was a 95'. I don't know if these are the same as the older flywheels. Good luck.
