stator wiring-150 force
oogaboga
1990 150hp force us marine 5cyl.3carb.-between the two coil packs is a screw terminal block with 6screws in it ,I took off 1,2 and put them back then took off 3,4 and forgot were they go #1,2,5 are good just need to know were #3,4 go.lost fire in #1 so was trying to check things out.any clues why #1 plug lost fire plz. help thanks :confused:
JB
Re: stator wiring-150 force
Engine problem, August.<br /><br />Moving to Force troubles.
alcan
Hi August<br />I will give this a shot. Here is what I have for the first 6 screw buss bar from the stator. Starting at the top,screw #1, two wires from stator,brown/blue and brown/black/blue connected to brown/blue to CD module. #2 brown/yellow from stator connected to brown/yellow to CD. #3 brown/blue to CD. #4 brown/black/yellow from stator connected to brown/yellow to CD. #5 brown/green/blue from stator connected to brown/blue to CD. #6 brown/green/yellow connected to brown/yellow to CD. I hope this helps.
