Stator
OCP
My 2004 ar230 has about 5000 watts at peak of stereo and the stock charging system will not keep up. Anyone else have a similar problem? And is there a solution?
Re: Stator
Ayuh,... A Bigger boat, or a smaller stereo....
A Big battery bank, 'n charge it later,..??
I'm guessin' you've got a outboard,..??
ONERCBOATER
Re: Stator
a smaller stereo will also make you much more popular :)
also no offense but peak is meaningless..... what is the RMS rating of the system, and do you always play it 100% loud?
jhebert
Ensign
Re: Stator
I have never had this problem.
keninaz
Re: Stator
Uhhh~turn the sound down and you won't draw as much power!:D
Don S
Re: Stator
Check your battery, and the charging system on whatever engine you have. I have no idea what a 2004 ar230, and I doubt if anyone else here does either.
EDIT: Just noticed this post is almost a month old, and the OP has not been back since posting the question.
