sidenberg
- Mar 2, 2010
- 206
I am getting excessive steam or vapor coming from the 2 portholes out the back of the leg, during idle and continues up to about 3000 rpm or what is called the "no wake zone". It does not occur when using ears or in a bucket. In the ocean it starts happening as soon as the engine is first started up and water begins to flow. The ocean water temperature here is a rather chilly 54 degrees and the air temp in the mid to lower 70's. I installed a new water impeller about three months ago. It seams as if plenty of water is flowing with a reading of about 125 degrees at idle? Is this steam normal and if not what should I be checking to correct it?
